Thanks, I just did it.
Two follow-up questions:
1) Should the ad code boxes at the Theme Panel remain empty?
2) In order to install automatic AMP ads, where should I paste the two pieces of code (secquency of commands and ad code)?
Hi Simion. The problem has disappeared. Thanks.
URGENT
Simion, the update has broken my landing page. All posts blocks are down now. I really need a fast solution here.
website: elpolaco.info
Hi. It happens the same to me with the Twitter button. I had to change my user name, and now it shows 0 followers. However, the link is OK.
Facebook and Instagram counters are OK.
My website is elpolaco.info
Jaime
Hi, Simion.
Ok, I will try so.
Can you just tell me how to get to this code page (https://www.screencast.com/t/rEBOoudPy) so that I can implement the modifications?
Thank you very much
