Thanks for the information
Then I’ll have to switch to another theme.
With around 100 subdomains, the project with TagDiv becomes too expensive.
I found out that the tagdiv – multi purpose icons are not displayed. Font Awesome’s, on the other hand, will be displayed.
<table>
<tbody>
<tr>
<td>Redaktion Landkreis Saarpfalzkreis</td>
<td><i class="tdb-cf-icon tdc-font-fa tdc-font-fa-envelope-open-o"></i></td>
</tr>
<tr>
<td>Redaktion Landkreis MZG</td>
</tr>
<tr>
<td>Redaktion Landkreis NK</td>
</tr>
<tr>
<td>Redaktion Landkreis SLS</td>
</tr>
<tr>
<td>Redaktion Landkreis WND</td>
</tr>
<tr>
<td>Redaktion Regionalverband Saarbrรผcken</td>
</tr>
<tr>
<td>Redaktion Bildung</td>
</tr>
<tr>
<td>Redaktion Coronainfos</td>
</tr>
<tr>
<td>Redaktion Gesellschaft</td>
</tr>
<tr>
<td>Redaktion Institutionen</td>
</tr>
<tr>
<td>Redaktion Kultur</td>
</tr>
<tr>
<td>Redaktion Kunst</td>
</tr>
<tr>
<td>Redaktion Landespolitik</td>
</tr>
<tr>
<td>Redaktion Organisationen</td>
</tr>
<tr>
<td>Redaktion Parteipolitik</td>
</tr>
<tr>
<td>Redaktion Polizeireport</td>
</tr>
<tr>
<td>Redaktion Verbรคnde</td>
</tr>
<tr>
<td>Redaktion Verkehrsmeldungen</td>
</tr>
<tr>
<td>Redaktion Redaktion Saarevent</td>
</tr>
<tr>
<td>Redaktion Redaktion Saarguide</td>
</tr>
<tr>
<td>Redaktion Redaktion Saarsport</td>
</tr>
</tbody>
</table>
<table>
<tbody>
<tr>
<td><i class="tdb-cf-icon tdc-font-fa tdc-font-fa-envelope-open-o"></td>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
</tbody>
</table>
it does not work. no icons are displayed
I found the settings ๐
When you mouse over the SIGN IN button, and then in the browser URL bar
That’s exactly what I’m referring to ๐
Anyone who can read has a clear advantage *laughs*
we have to deal more with the system ๐
Thank you for your efforts :).
We found that we used the wrong category filter on the results page.
after we have entered search – current search there, the search results are also displayed ๐
now we will adjust the texts of the results page ๐
What would be good would be if there was a manual with ALL the features that the theme can do to look in ๐
e.g. the search results section function ๐
However, this text is always displayed ๐
It doesn’t matter how the date is displayed.
So in the header a result is displayed in the live search.
If you then click on return, you will end up on the 404 page, as you noticed.
So we didn’t notice that the photos or icons were missing ๐
if you press return in the result at “HEADER LIVE SEARCH” you end up on the 404 page.
in the url you can see https://www.saarland.today/?s=csd&post_type=post
This reply was modified 3 years by
kus-info.
What I also noticed is that no categories are displayed for the CPT’s in the results displayed in “HEADER LIVE SEARCH”.
No matter what is entered under SEARCH FORM in the field “CPT Search / Post Type” nothing can be found.
Nothing is found if you leave the field empty
I found the cause or the problem. At least as far as the live search header is concerned.
If I enter a single post type in the “Post Type” field, e.g. post or post_galleries or any of the existing post types it works. However, if I enter more than one post type, it no longer works. (we are currently working with 13 different CPTs, but there will definitely be more)
A little information on the side ๐
We know the problem when it comes to the smooth cooperation of the different plugins.
Therefore, in our test environment, we only work with the plugins that are absolutely necessary.
in this case, they are:
All plugins from TagDiv (except for the mobile themes)
such as
NextGEN Pro (we also test if our galleries are found)
WP Media folder (because of the better clarity of the article images)
WP Original Media Path (we have outsourced the article images to a separate subdomain for better performance)
Custom Post Type UI and Custom Post Type Permalinks.
But even if we deactivate these plugins, the search in the standard search does not work.
If the error still occurs, as in this case, it is not due to another plugin. ๐
the link to the live page is https://www.saarland.today
the link to the test page is https://st.saarland.today
OK Thanks
is there a date when the next update will come?
OK, thanks
It’s about the fact that I can, for example, select the post type in Flex block 1, but if I try to set a category filter it doesn’t work, because I only get the standard categories displayed there, not those of the custom post type.
It’s not about the post template.
We know how it works and have no problems with it.
The problem is that the custom post type categories we created are not displayed in the filter, so we have no way of getting them displayed anywhere.
p.s. The field type selection fields does not work either
we have found a solution.
It’s quite complex, but seems to work ๐
OK This means that in the case of a page with this template e.g. 5 years of work should there be 60 entries?
Or will the display be switched to annually in the event that 12 months have been reached?
In case 1 this function is unusable, in case 2 it is acceptable.
respectively daily archive ๐
This reply was modified 4 years by
kus-info.
With us, only administrators, i.e. no editors, are allowed to work with the TagDiv Composer.
The administrators, on the other hand, are not allowed to enter any content, so in our case it is not possible for an admin to enter or change the imprint, the terms of use or the data protection regulations, for example.
how are we supposed to do that?
I found the function ๐
