Home User profile
tagDiv Member
I’m going to send a video to the contact email where I think you can see the problem.
Yes, it works because version 12.6.3 is now installed as I have already explained. The problem is that when I upgrade to a newer version it stops working and I have to go back to this version.
You can watch the video here: https://www.laneurosis.net/
As it plays I understand that there is no problem with the API key. If I update it stops playing.
