Hi, I installed the latest version of thema and double checked my settings on yoast and they all seem correct …
The only thing is that since I installed version 10 of your thema I have had a 30% drop in visits
The collapse is visible from seo zoom.
I reduced the number of plugins from 24 to 13 … practically keeping only the essentials, counting that 4 are from thema 1 for the wordpress editor and the other for the privacy banner.
I attach the trend taken from seozoom with the collapse of the first installation of version 10 of thema.
How can I solve it? Do I have to go back to 9?
Thanks,
Marco.
https://ibb.co/2ZL9pQD (The statistics of seozoom)
This reply was modified 6 years by
liberoarbitrio.
I solved
Hi will this option be developed in the future? 80% of my content is on theme child …
Hi, I have now activated the site in AMP Standard mode
http://www.libero-arbitrio.it
Hi I have disabled the plugin so as not to encounter various errors …
Unfortunately I cannot use your mobile plugin because my site uses a thema child.
(I hope you will give this chance in the future)
When I installed it in the three options I chose standard.
Currently on my site only the standard pack and the div composer tag are active as I do not use anything from the cloud.
If you want I send you the credentials to access the site.
Thanks for the assistance
But disabling the structure should take Yoast’s, how come he doesn’t take it?
Thank you
Thanks for understanding the problem, I will wait for the next update.
With regard,
Marco.
ok thx.
Marco.
Hi maybe I can’t explain myself, I use Yoast, when I enable the option (see image) within 48 hours visits drop by almost 30%, when instead I should have a benefit from what is written in the control panel of thema.
With regard,
Marco.
https://ibb.co/HB52599
Hi, I use yoast as a plugin, but when I enable thema to use the markup of the plugin, I lose visits to posts, I don’t know if I explained myself.
I think there is some conflict between the thema option and yoast
Hi, I updated thema to version 10.3, but when I enable the DISABLE ARTICLE SCHEMA option, I get 30% more visits.
With regard,
Marco.
Hi I did all the tests you requested but the problem persists, I sent mail to your support as you indicated.
Cordially,
Marco.
We are waiting for developers to understand what to do …
Hi I have enabled the plugin amp, the native function does not work says curl error 28
Functionality the transitional and the reader which however have strong limitations …
Marco.
Hi this is the test after disabling the google fonts and loading those de thema in local …
With regard,
Marco.
P.S. maybe they would be faster if they were in the new woff2 format
Hi I followed the advice and tried other methods too but it seems to be the loading mechanism of the site to load the woff? 16 resource at the end, lengthening the loading time of the site’s First Paint.
Thank you,
Marco.
https://wetransfer.com/downloads/b6e7e55eeac0b51e639e02fe22a65ca820190501110814/c0aaabd44feb02f2bd6d23d9bfe3739620190501110814/63750b
Marco.
Hi I have read this version 9.7.2 update
fix: AMP works properly when using child theme.
Does it mean that I can activate AMP with Costomizzazione on thema child but not the mobile plugin?
Thank you
Hi, with the new update is the customization on thema child compatible with the mobile plugin?
Marco
Thanks for your response. In the future also develop the possibility that the mobile plugin theme also works with thema child with some customization?
The problem that I find in the google console are the duplicate title tags of the pages and the meta description.
I thought that with the endless scroll disappeared because it created a unique page, invce from how she says it remains only loaded vertically.
The correct question is therefore:
“How can I solve the problem of duplicate title tags and meta descriptions”. Use Yoast and it’s set up correctly but google finds cmq that data in the pages.
Thank you,
Marco.
