Hi I have activated the amp plugin recommended by you among thema plugins.
Everything works perfectly except for 3 things:
The search lens does not work on mobile or on desktop
Sharing icons do not work on mobile or on desktop
The infinite scroll does not work on mobile or on desktop.
How can I solve it?
http://www.libero-arbitrio.it
I just checked your website that I can not find an amp posts, the amp plugin is still activate ?
We recommend to use the amp plugin with mobile theme plugin with one of these two options -> https://i.imgur.com/kvgo2WV.png
If there is a problem, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Let me know the results!
Hi I have disabled the plugin so as not to encounter various errors …
Unfortunately I cannot use your mobile plugin because my site uses a thema child.
(I hope you will give this chance in the future)
When I installed it in the three options I chose standard.
Currently on my site only the standard pack and the div composer tag are active as I do not use anything from the cloud.
If you want I send you the credentials to access the site.
Thanks for the assistance
Hi, I have now activated the site in AMP Standard mode
There are still no amp posts.
Please send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look. Include a link to this topic in the email.
