Home User profile
Max
tagDiv Member
Max
tagDiv Member
ok I will try with css
Thank you
Max
tagDiv Member
I had already tried, but it does not work. On the dekstop version it is ok but if you put the mobile version it is very small. You have to try putting the mobile version
Max
tagDiv Member
No even if I put the raw HTML code from the composer there is still the same problem. What I said in the previous post is that I tried to make a simple .html file locally
Video here -> https://drive.google.com/file/d/1OK_hRqRIaGWy1m2syVzPJOj68BCT_u0Z/view?usp=sharing
Max
tagDiv Member
Yes yes of course I tried everything I could, but every time you use the cabinet it becomes tiny. I think it is a wordpress or theme problem. I say this because I tried to create a simple html file and there it works
Max
tagDiv Member
Thanks for the reply, I need to put it on a page. I have tried various ways, certainly change height and width but nothing from mobile the size shrinks as shown in the image I attached to you.
Max
tagDiv Member
ok Thank you
Max
tagDiv Member
in a page no post
Max
tagDiv Member
Max
tagDiv Member
hi pnadolny
how did you solve it? I have the same need to show text only on the first page of the category
Max
tagDiv Member
I would have to create dozens of menus can’t be done plus I would have to update the menus every time I add an article.
But since your template is seo optimized and the structure <ul ><li >< /li >< /ul > is very important. You could implement it in a next update.
Thank you
  • This reply was modified 2 years by Max.
Max
tagDiv Member
ok perfect! Thank you
Max
tagDiv Member
Yes of course the advertisement is automatic, but as I have shown in the attached images you can disable the area where you do not want to see the advertisement.
With the Today News PRO theme it works (I don’t see the ads in that part) with the Style Pro theme instead it doesn’t work even if I disable the ads it keeps showing me the ads.
Now to solve it I should change the theme but it is a long work
Max
tagDiv Member
The link was in the image.
any article on bloggaviaggio[dot]com
I don’t have any code handles, all google i just inserted via tagmanger the code you find attached here: https://ibb.co/dtgPTjm
Max
tagDiv Member
ok, done!
Max
tagDiv Member
Hi, the template is installed -> https://prnt.sc/CMjGE26Rnz_O
Max
tagDiv Member
You can see the screenshot here
https://ibb.co/LgCPrst
https://ibb.co/ss3ZbwS
https://ibb.co/5RmpTT4
https://ibb.co/TwSCfR7
https://ibb.co/Jm5n9Wn
I’m working on new hosting so I haven’t activated dns pointing yet, so to see the site I set my hosts.txt file like this:
80.88.84.39 http://www.thename.com thename.com
could that be a problem?
Max
tagDiv Member
probably the problem is this: the antimalware on your server where your site resides … automatically deletes the css-analyze/css-analyze.php file so try contacting your hosting provider and asking them to whitelist it. Thanks to Lucian I solved it this way.
Max
tagDiv Member
ok
Max
tagDiv Member
thanks for the availability … I made several attempts and found that the problem was a plugin. I’ve resolved it.. you can close the ticket
Max
tagDiv Member
yes I know I did all the tests … but I can’t understand why it shows me the Plesk icon and not the WordPress one that I set. The problem is not in the browser but in the indexing or sites like this https://www.wmtips.com/ if you enter my site it shows you the wrong favicon. I’ve tried everything but nothing! Thanks for the support anyway
Max
tagDiv Member
Yes I had done this operation https://ibb.co/99zv4q2 but nothing.
Any other ideas?
Max
tagDiv Member
I have tried many times and now it has saved it. You can close and sorry for the post
Max
tagDiv Member
Viewing 25 posts - 1 through 25 (of 47 total)
