Hi, I just visited your site: https://glamsham.com/ you have the h1 tag twice and 4 times alt=”Logo”
It’s simple when you put the sticky header with the logo that already gives you 2 h1 tags plus 2 for mobile, then you have to deactivate 3 and leave only one, problem, that’s it you still keep 4 times the title tag and 4 times the Alt tag, and with respect to Google it’s forcing on the title and keywords at the same time, really bad for SEO.
Good morning,
Really no suggestion, you need an h1 tag for each page with a different title and alt, you’re asking me to deactivate the h1 tags on other pages, it’s no longer SEO.
Why the h1 tag several times and especially why the same titles of the h1 tag on all pages, it deserves an emergency correction, without this correction your site is of no use at all, also important template-blocks are devoid of title tag , the titles and alt tags are important for SEO, with you having the impression that it is only decoration, there is no point in having the most beautiful site if it is not visited or poorly indexed in google.
How to put a different h1 tag for each page? you must allow at least one h1 tag to be activated, which one?
Do you have a solution, or a function to implement to troubleshoot?
This reply was modified 2 years by
max-4.
Even if you deactivate the h1 tags by default we use the same tag and h1 and title on all pages, really null for SEO, duplicate of the h1 tag detected
Example on the home page, it shows you this:
“J' ;en ai”
And on the article page it shows you this:
“J&rsquo ;en ai”
max-4.
It is only with your theme that it appears like this, not with the other themes, it is a significant error for SEO and referencing, and I am not even talking to you about the density of the words which is wrong because of That.
max-4.
https://ibb.co/LJt9PGk Capturer 1
https://ibb.co/6J3JmKF Capturer 2
Here are the 2 captures of the results typed into Google with a straight apostrophe and a curved apostrophe, hence the benefit of having a language file to correct newspaper errors, your template is of absolutely no use if it is penalized by Google because of this error, and I will even tell users to change themes rather than waste their time configuring for zero results in the search engine.
Do the same search with straight and curved apostrophe
Pixar donne vie à ses films d’animation avec Studio Music
Here is proof of what I say, in google with the different apostrophe (‘) (‘), 2 different results.
So don’t tell me that it’s normal and that there are no consequences for SEO
For information, Google is the source he visits and not the fronted
you have to avoid newpaper then in this case and install another one than yours which does not respect SEO, what is the point of having a nice site if it is penalized on Google because of that.
Yes I say well penalized.
Where are the language files for the newspaper theme?
It looks a bit amateurish I think without a language file?
Sorry to tell you this but your template is not suitable for France or even certain European countries, even your demo displays apostrophe problems ‘
Here is a screenshot of the source of your demo:
Do you have a solution or I need to change script other than newspaper:
You ask me to continue the conversation by email and then you do not respond and give no help regarding the apostrophe problem and I would even say the language problem, because no .po or .mo file for languages with the newspaper theme, not normal , must script without this correction is far from being optimized for SEO, what’s the point of making a beautiful template if no one can see it?
Here is the link to the capture with the error:
https://www.lapetitecoquine.com/caracteres-Capture.JPG
I’m not going to download software I don’t know just to send you a screenshot.
Here is the character error we have:
une maman d’Istres”>Rencontres infidèles avec une maman d’Istres
There is not even a language file for the newpaper theme, for France it is a problem and it is not professional
I think you are hoping for good results with false advertising when it is impossible to have a good score above 90 on mobile on the tagdiv newspaper, just by activating td-composer or the cloud already it is damn it, 90% of the default css and js is unused and it’s too big a job to delete, all the default css are in place it doesn’t install only the css or js we use but all of them , not to mention that even if you use only one font, google finds about ten when they are not activated, and I’m not even talking about the number of different css and js instead of grouping.
Today your tagdiv is unusable for seo and as I told you, there is no point in having a very nice site without visitors if google downgrades it because of your too heavy script.
Cordially.
Thank you for your return, in private message it is possible to send you the url?
Why make Templates pretty but don’t respect the conditions, too slow, have a very nice site but no visitors, what interests, I sincerely hope that themeforest will apply conditions to be able to sell Templates with them,
PageSpeed Insights is applying new measures and it intends to penalize sites that do not respect it, google pays big fines every year for exceeding bandwidth, so yes for chrome to use less bandwidth it will penalize slow sites.
And it has already started.
So yes your templates are super well done but have no interest, it is even a big waste of time for us to go after them to optimize the speed, improve or we change the dairy as they say here in France.
