Hi Bogdan,
Any suggestion on specific size of image? I use in the homepage Block 22 and Block 6 (with thumbnails). What’s the best size of the image so that the feature image is clear and the thumbnail won’t be cropped?
Hi Simion,
Thanks for your help. I have another question but not related to the first topic. Hope you can help me again with this. Is there a way that the feature image will not be cropped when it’s use as a thumbnail? If I use different blocks the thumbnail changes and sometimes crop the images. What’s the correct image size for the feature image so that the thumbnails won’t be distorted?
Thanks and hope to hear from you again.
