A bunch of problems anf questions
Hey,
i have three different problem topics:
– Mobile Plugin:
When activating the tagDiv Mobile Theme plugin + AMP some Computer/Browser showing the Homepage every time in the mobile view. What can i do?
– Youtube Social Counter
The Youtube Social Counter doesn’t work correctly. I put the channel ID in the widget but it doesn’t work.
I put it in my sidebar, but if shows only “0”, so i must put a fixed number
https://arbeitsunrecht.de/brennpunkt-betriebsrat/
– Ad Plugin
I need a plugin for persionalized ad’s for different categories with is compatible with the theme. The newspaper ad doens’t have so much setting options.
If you need more information for the different questions, please tell me.
best regards
Hello !
1. If mobile theme is rendered on desktop that is because of the cache. 99% of this cases the mobile theme is rendered on desktop because of the Cache plugin. We recommend using the WP Super Cache: https://forum.tagdiv.com/cache-plugin-install-and-configure/
2. Please make sure that the Youtube Api is integrated as you can see here: https://forum.tagdiv.com/youtube-api-key/
3. Unfortunately we have not tested any ads plugin so we cannot recommend any !
Thanks for your answer.
1. We already had the plugin installed, but after i put the same configuration like you, now it works. thx!
2. I can not integrate the youtube api. At my theme panel i can not fiend the box to fil in:
At the widget i put it like this:
3. Thats regrettable 😉 thx.
And now i have a nother problem with the mobile theme. It only shows the latest article but not the same like my startpage at the computer.
Any idea why?
Hello !
For the youtube to work please remove and re-install the tagDiv Composer plugin.
The Mobile theme was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme.
You will have to recreate your pages into the Mobile editor or completely disable the mobile theme.
Hey,
i reinstalled tagDiv composer and now i can find the Youtube API field. thanks!
But i don’t found a solution for the mobile plugin. I want to use it, but it shows not the correct things.
My mobile theme shows this:
But i want that it shows my page in this way: 8Its a page of a friend of me, he also uses Newspaper)
Thanks for your help.
If i try to enter the YOutube-API-Code i get this error code:
“NOTE: ** This field should contain the unique URL for your undefined profile!
please Enter a valid URL.”
What can I do?
Your note about the mobiel theme doesn’t help me at all. You don’t respond to my last objection.
Hello !
On youtube that is a bug that can be ignored. Also if you update the Newspaper theme to 10.3.1 you will see that it has been fixed.
As for the mobile theme please note that you are seeing it in this way it is because that is the mobile theme. As for your friends theme I can see he has some custom work done to it.
