a few questions for single post setting
Q1. For the single post, how to change the backgroup & text color for catalog?
I had found it that part, just don’t know which part is for backgroup & text color.
My requiremnt is simple, just black & white like below
sample
Q2. I don’t know the name for this functions, thus I just use below image for explaining.
sample
how to find the setting for this part? Since some single post will show, but some single post will not.
I guess that it is about the setting of date range. I just don’t know the name for this functions and where to find?
– will show
https://starwarsbase.com/%e6%98%9f%e6%88%b0%e6%96%b0%e8%81%9e/%e5%bd%b1%e9%9b%86obi-wan-kenobi-%e6%ad%90%e6%af%94%e7%8e%8b%e8%82%af%e8%ab%be%e6%af%94-ewan-mcgregor-hopes-to-return-as-obi-wan-again/
– will not show
https://starwarsbase.com/%e6%98%9f%e6%88%b0%e5%95%86%e5%93%81/sideshow-collectibles-the-mandalorian-carbonite/
  • This topic was modified 3 years by Man Kam.
If you want to change the text color of your breadcrumbs and you use cloud template, then you need to access a post, edit with the TagDiv Composer, click on the element and you’ll find the settings in the left side of the screen.
You can disable the option the Auto Loading on the Single Post Template edit with tagDiv Composer -> Show site wide settings => https://www.screencast.com/t/4RnV1CnxiuA -> https://forum.tagdiv.com/infinite-loading-single-posts/
example
Thank you for your reply. Following above answer, I have try few time. But cannot re-build above style.
Is it possible to advise for me? Which parts I need to adjust?
p.s. ignore the logo
  • This reply was modified 3 years by Man Kam.
Please let me know exactly what you need to achieve. From what I can see, you use the tagdiv composer, so you can edit the pages and check the settings.
sorry for my short & unclear questions.
Yes, I am using tagdiv composer for editing the cloud templates.
My questions is that I want to set the style for Category as above images. (light gray frame, with black color text).
Since there is too many options, I just don’t know which parts I need to set. Could you please advise if it is possible?
