I have used add ‘Text with title’ element in the past (no problems), for adding iframes for mail subscriber forms and other things. I have recently tried to add ‘text with title’ element and when I click on ‘edit content’, the WP Editor pops up but then it gets stuck loading with a looping circle but it never loads.
I updated to version 11.5 Newspaper and perhaps it broke then. Is this a known issue? Is there a fix?
Please update to the last version. The problem was caused by the compatibility with WordPress 6 and was fixed in version 11.5.1 -> https://tagdiv.com/newspaper/?utm_source=forum&utm_medium=menu&utm_campaign=forum_loggedin&utm_content=92178
Disabled all the plugins except Tagdiv ones, but text with title (WP editor) Keeps being stuck loading with a looping circle
Please open the console and try to save something.
I think will you have a 403 or 404 error, so please check this topic -> https://forum.tagdiv.com/topic/wp-editor-for-text-with-title-and-column-text-not-updating-content/ and try the suggestions. Also, please check the cache, clear/purge all cache.
I emptied the cache and don’t have the Cloudflare’s Rocket Loader installed. PHP version is above 8 and have all the requirements. Any other options I can try?
Did you check the console? Maybe the problem is caused by some settings on the server.
Also, check this guide and make sure you do not have in the .htaccess file some lines with “Deny all”!: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
