Ads insertion Problem
Dear support team, I am facing a problem while inserting google ads in theme panel.
I have inserted all codes in feeds ad and a bit more in theme panel > ads section but the problem is these are not yet implemented to my website and nothing is showing on home page in addition I would request you to please guide me on it
Does this ads section auto enable ads or we need to insert in home page manually?
Please review and give me a best solution to sort it out.
Hello @nasirnadeem628 !
In the cloud templates, you can add the ads when you edit the post with TagDiv Composer in the element called ” Single Post Content ” in the tab ADS. Documentation here: https://forum.tagdiv.com/article-ads/
Or you can use the element called “Ad Box” from TagDiv Composer, and there you need to add the ads: https://forum.tagdiv.com/ads-adsense-overview/
Hello Support team,
I placed an advertisement code on my home page, but regrettably, its performance on page speed insights is below my expectations. Despite reducing the size of all images, the issue still persists. Hence, I am sincerely requesting your assistance in resolving this matter. Can you kindly provide me with a solution to optimize the performance of my home page?
Thank you sincerely.
Please note that page speed or optimization is not covered by the support team: https://forum.tagdiv.com/newspaper-theme-support/
Thank you for understanding!
hello dear please help me out
my licnese are showing me the date to assign to another website so that should i do??
Do you want to move the key to a different website? I see you are still using it on the websites where the key is assigned now. If you want to move the key and the theme to a different website, this requires removing them from the previous websites.
Please mention what exactly you would like to do.
