After installing tagDiv Speed Booster Creating issue
As right now I’m using GZip Ninja Speed Compression and tagDiv Speed Booster to speedup site performance but ads are laying our of the front page, its been the issue since for long time, still it didnt soled please open any article and you will find the ads are moving out of the content body.. previously it was not there when I have installed or activated Speed Booster Pack and deactivated tagDiv Speed Booster, even Now I have deactivated all the boosting plugins and activated tagDiv Speed Booster but still the issue appears!
Best Regards
Mantosh Pal
I have inspected some of your articles but I do not see any ad related problems – https://www.screencast.com/t/kBdRziEhjM1b – https://www.screencast.com/t/O9auVkQ6hJ in your post page. Maybe the compression plugin you are using is not fully compatible with the theme, this meaning unexpected results. If the problem reappears, you should try to disable all the plugins except Visual composer, clear the cache and purge cdn files. However you should consider updating the theme and the required plugins to the latest version – https://forum.tagdiv.com/how-to-update-the-theme-2/ – https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
Can you see the articles?? on that articles you will see adsense ads are floating outside.. is there any solution to this.. just open my site and go to any article you will see adsense ads middle content which is floating right side to the side bar thanksss.
And WPBakery Visual Composer is not activated as I click on approve and it redirects and says NO LICENSES FOUND! why so? how can I activate it! thanks!
Please first sold the After installing tagDiv Speed Booster, after activating it the adsense codes are floating right side. please please.. Need to fix this on your template!
The worse service ever experienced! Will never purchase another template from you guys and will suggest techviral and other sites of my friend not to use your service anymore because you guys dont have any solution for your own template!
Will remove your template now for ever! thanks for the grand support!
I am sorry, but I did not see at that time any problems like you describe related to the article ads. Maybe the problem is intermittent and was not displaying at the moment I was inspecting it. We try to provide the best support and solve all the problems that arrive when building your site using the Newspaper theme, if possible. But this is done with dialogue and patience, to identify the problem quickly and find a working solution for it based on the information received. Also please try to post a single time and not reply in your topic, because this refreshes the topic and places it last. We try our best to answer all the topics, from oldest to newest, in the allocated support hours.
You do not need to activate the Visual composer plugin, it is already activated as specified in the link below and you do not have to worry about the activation warnings – https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
Please let us know if you need further help.
Thank you for understanding!
