You are referring to this option -> https://i.imgur.com/Replq0R.png, this option can increase the server effort if your traffic on the post is high. That option will allow the server to check and count each enter/refresh of post when you use a cache.
Now, it also depends on the server that you use and what resources are allocate for your website, if it is a dedicate server, then should not be a problem.
Also, the option can be removed if you are not using filters base on the most popular posts.
I think that this can be done only if you not cache the posts, but then those will load slower.
Also another solution will be to also use CDN -> https://forum.tagdiv.com/cloudflare-cdn/ also the server need to provide you the resources to can handle the traffic from your website -> https://i.imgur.com/mDORDjc.png https://forum.tagdiv.com/requirements-for-newspaper/
