I got this message from Google about AMP
Search Console
AMP issues detected on https://marketingresults.club/
Search Console has identified that your site is affected by 6 AMP issues:
Top Errors
Errors can prevent your page or feature from appearing in Search results. The following errors were found on your site:
External stylesheets are not supported, except for allowed font providers. Use the document inline ‘style amp-custom’ tag instead.
A mandatory AMP HTML tag is missing from this document.
Only amp-boilerplate and amp-custom ‘style’ tags are allowed, and only in the document head.
The tag ‘img’ should be replaced with an equivalent ‘amp-img’ tag.
A tag on this page requires an AMP component ‘script’ tag, which is missing.
We recommend that you fix these issues when possible to enable the best experience and coverage in Google Search.
Hello !
Please make sure that you have accomplished all the system requirements as in our documentation here: https://forum.tagdiv.com/requirements-for-newspaper/
And please make sure that AMP has been installed properly as you can see in our guide here: https://forum.tagdiv.com/tagdiv-amp-plugin-tutorial/
