Hello My URL is – “sustainabilitynext.in”
From today morning, I am getting a strange error.
It is showing on dashboard, at a glance area as “1 URL w/ new AMP errors”
If I click on it it takes me to “AMP Validated URLs”
where it shows “The site is using transitional AMP mode with auto-sanitization turned on, the validation errors found are already automatically handled.”
How can I fix this error? Can you please help me?
Hello !
What you are seeing is not exactly errors, you are seeing the plugin sanitizing the page and removal of unnecessary scripts to make AMP compliant. You should check the AMP page and if the content is OK, then yes ACCEPT them. Then, check the AMP version via the Google validator.
Can you please explain this in detail, as I am not able to understand “what is sanitizing the page?” and where can I get the AMP page to accept?
Please make sure that you have the mobile theme plugin and amp plugin install and activate, after that make sure that you are using one of those two option -> http://prntscr.com/p3nwun and set in AMP only the posts like this -> http://prntscr.com/p3nx8m
Thanks for your instructions, but I am not using the mobile theme on my website.
I have deleted the AMP plugin.
Will there be any problems for me in the future if I delete the AMP plugin?
