AMP Problems
Hi, I’ve activated the AMP plugins.
However, when I activated it. None of the pages are working if i click from the sidebar. This error also showed up.
The AMP plugin performs at its best when persistent object cache is enabled. More details
What am i suppose to do?
Do you use only the amp or you are using the mobile theme + amp, if you are using the amp with mobile theme, then you need to know that on pages you need to set the content in mobile editor -> https://www.screencast.com/t/ebUIzt4se
If this is not the problem, please deactivate ALL plugins except tagDiv Composer, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
If there i still a problem, please provide me link where i can check these problems.
I have same problem
Hi gumball44,
Please provide some details and screenshots about the problem you are facing!
