I have my theme set up to auto load the next post in the same category previous.
While it is working on desktop, on mobile devices the next article won’t load:
You can see an example post here: https://smarts.co/opportunities-for-accredited-investors/
Now, when using Inspect on Chrome and switching to mobile view, it shows its working, but it’s a different story when actually using a mobile device like an iPhone.
Can you point me in the right direction to get this to work? It is affecting my time on page, usually readers like to read through to the next article and now it isn’t working correctly.
Thanks in advance for any advice you can provide.
Brian
Hello Brian!
In your console, there are a lot of 403 errors.
It’s possible to be from the firewall or security module which blocks the admin-ajax.php request, which usually displays a 403 or 404 error.
If you don’t use a security plugin, please ask your host about this, maybe you have a security module that blocks this.
If you use a plugin like Wordfence please set it in learning mode.
Also, if you are using Cloudflare, please make sure that is set as in our guide https://forum.tagdiv.com/cloudflare-cdn/, you need to disable the Rocket Loader.
Examine some other potential interfering factors: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
Let me know the results!
