Auto Load article problem – Next/previous articles not auto loading after update
We are facing a peculiar problem.
Before the latest theme update our articles on the desktop website – http://www.gadgetbridge.com were auto-loading/Infinite scroll.
however, now they are not auto-loading in places like Microsoft Edge browser they are auto loading after long time. The next/previous article does not auto-load. In fact, it does not load only.
Please help.
Edit
On further investigating, we found that by turning off WP-Rocket plugin the auto-load feature starts to work. We rolled it back to previous WP-rocket version and it is working.
However, we have the same plugin in our other website motorbridge.com with newspaper theme and same settings, there with Wp-Rocket turned on auto load is working.
Very strange.
  • This topic was modified 3 years by SP1.
Hello @sp1!
Edit the homepage with the TagDiv Composer, and use a flex block and there you can choose the pagination you need: https://prnt.sc/VNGgaCDVcDB5
Hi Bettina,
thanks, but I am not talking about the home page. I am talking about the article templates/single post template.
Like this – https://www.gadgetbridge.com/how-to/top-ways-to-turn-off-auto-emoji-on-discord-mobile-and-pc/
https://prnt.sc/NncYbPDkSdrX
which is in Show site-wide settings in the tag div composer.
Hello @sp1!
I can see that the auto-loading feature works great.
Where exactly is the issue?
hi, it loads at times and it does not load at times or takes a lot of time to load. Check it out Microsoft Edge browser.
As said it could be a problem with WP-Rocket plugin, but, we have the same plugin in our other website motorbridge.com with newspaper theme and same settings, there with Wp-Rocket turned on auto load is working.
Hello @sp1!
Check the settings’ configuration to see if they are the same. The host can also affect the time it takes to load if you have more elements on the pages, for example. Disable the lazy load animation from here: https://www.screencast.com/t/O5pfqQdb
The functionalities appear to work as they should.
Thanks, will try that.
we are on a dedicated hosting. And we were not facing this issue before the last newspaper theme update.
As said it could be a problem with WP-Rocket plugin, but, we have the same plugin in our other website motorbridge.com with newspaper theme and the same settings, there with Wp-Rocket turned on auto load is working.
We are also having issues on the edge – our site in that browser has turned into a mobile design.
Hi Bettina,
On further investigating the console we are getting this error –
jquery.min.js?ver=3.6.1:2 jQuery.Deferred exception: Cannot read properties of undefined (reading ‘autoloadScrollPercent’) TypeError: Cannot read properties of undefined (reading ‘autoloadScrollPercent’)
at Object.init (https://www.gadgetbridge.com/wp-content/plugins/td-cloud-library/assets/js/js_posts_autoload.min.js?ver=d72a7d54cd61ce0a128c0a91d76ef60a:3:208)
at HTMLDocument.<anonymous> (https://www.gadgetbridge.com/wp-content/plugins/td-cloud-library/assets/js/js_posts_autoload.min.js?ver=d72a7d54cd61ce0a128c0a91d76ef60a:12:154)
at e (https://www.gadgetbridge.com/wp-includes/js/jquery/jquery.min.js?ver=3.6.1:2:30038)
at t (https://www.gadgetbridge.com/wp-includes/js/jquery/jquery.min.js?ver=3.6.1:2:30340) undefined
S.Deferred.exceptionHook @ jquery.min.js?ver=3.6.1:2
jquery.min.js?ver=3.6.1:2 Uncaught TypeError: Cannot read properties of undefined (reading ‘autoloadScrollPercent’)
at Object.init (js_posts_autoload.min.js?ver=d72a7d54cd61ce0a128c0a91d76ef60a:3:208)
at HTMLDocument.<anonymous> (js_posts_autoload.min.js?ver=d72a7d54cd61ce0a128c0a91d76ef60a:12:154)
at e (jquery.min.js?ver=3.6.1:2:30038)
at t (jquery.min.js?ver=3.6.1:2:30340)
VM6459 adsbygoogle.js:43 Uncaught TagError: adsbygoogle.push() error: No slot size for availableWidth=89
at yn (adsbygoogle.js:156:67)
at An (adsbygoogle.js:154:1165)
at Gn (adsbygoogle.js:159:91)
at Io (adsbygoogle.js:183:202)
at dp (adsbygoogle.js:187:105)
at cp (adsbygoogle.js:186:1251)
at lp (adsbygoogle.js:202:301)
at e.client (adsbygoogle.js:196:42)
at Td.ha (adsbygoogle.js:43:224)
at zj (adsbygoogle.js:90:19)
22The resource <URL> was preloaded using link preload but not used within a few seconds from the window’s load event. Please make sure it has an appropriate as value and it is preloaded intentionally.
Any solution to this?
Examine some other potential interfering factors: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
Make sure that all the requirements are set as here: https://forum.tagdiv.com/requirements-for-newspaper/
I hope that helps you!
