Background Ad and Mobile theme problems
I have a few problems with the site since changing the front page to a new template:
1) The background ad image only shows when a user is logged in. The site is http://www.Comicsbeat.com.
Here’s a shot of the background ad showing in the TagDiv editor:
https://imgur.com/a/oTOxddd
2) A more complex problem is the mobile theme. I have Mobile Theme enabled as shown below
https://imgur.com/ATkD07c
I created the desktop theme and then clicked create a mobile theme and edited that so it looks decent – can use some work but readable:
https://imgur.com/2zEpkv3
However when I check the Chrome inspector or look on my phone the images are desktop size and the site is unreadable:
https://imgur.com/aEVVOSw
I tried disabling the TagDiv Mobile Theme plugin so that the default theme would show up but that didn’t seem to work.
Thanks in advance!
1. There should be a plugin conflict because even the scroll is not working. And if you click everywhere on your site, it will redirect you to another site. Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
2. If you want to see the mobile page for your desktop version, then you should uninstall the Mobile theme & AMP plugin.
We have 3 options for mobile versions that you can use:
1) Responsive version: A responsive version of your website looks similar to the desktop version. TagDiv Composer is used to edit the page.Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. There, you can see your mobile version and edit or adjust the elements to look better.
2) Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages
3) Mobile theme plugin: The Mobile Theme is a performance-optimized theme included in the main Newspaper theme that only loads on mobile devices. It comes with its own templates and designs for pages, posts, categories, etc., so your current templates from the desktop theme will get converted to the mobile theme layout. Please see https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/ for more information.
A full explanation is here: https://www.youtube.com/watch?v=SpGkOnJeNZY
If you need to use the mobile version 1 or 2, then you need to uninstall the Mobile Theme plugin and AMP.
1) The wrapper is a background ad so it is supposed to goto another site when I click. However I suspect you are right and its a plugin conflict. I’ll try that method.
2) I have, O believe your second option selected. I created a mobile theme for my current template but it is not rendering properly. Should I disable the Mobile Theme and Amp plugins?
Yes, please disable the mobile theme and AMP plugin.
I turned off the AMP plug in and the TagDiv Mobile plugin.
And the front page rednders as the web version on mobile which is making the site unreadable.
https://imgur.com/a/5RAQPD1
What I would like to do is turn on the default mobile theme that comes with WordPress. How do I do this?
You can adjust it and add some padding to the rows in the CSS tab of your mobile viewport (see point 1) https://prnt.sc/Ut0ztV89x03W)
If you want to use default templates (which I do not recommend), then you need to use the Standard Pack plugin, and you can’t customize it with the tagdiv Composer. You will have only the theme panel’s settings. For example: https://forum.tagdiv.com/design-post-pages-using-default-templates/
These answers were completely confusing and didn’t help me much. By trial and error I managed to get things working.
