BIG problem Visual Composer
I installed everything according to instructions. When you modify the homepage is not using Visual Composer adds features and blocks. please, give me an advice. thank you
Please make sure you install the visual composer plugin that comes with the theme: http://screencast.com/t/74bsUYY7xX And make sure you use the latest theme version.
https://forum.tagdiv.com/how-to-update-the-theme-2/ – https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
If this is the case, then try to disable all other plugins except visual composer and check the error again.
Let us know how it goes.
