Can’t Fix my Homepage – Please HELP
This is my website: https://www.hospitality-school.com/
This is how Cloud Templates are: https://www.awesomescreenshot.com/image/49239871?key=82e206b628116684513978f962c01ec8
This is how I designed it and want to look like: https://www.awesomescreenshot.com/image/49239883?key=46e37f28dd3b71447a33192458c9ca79
BUT WHEN I TEST IT IN DIFFERENT BROWSWER AFTER DELETING CACHE FROM SERVER SIDE AND BROWSER SIDE, IN PINGDOM AND OTHER TOOLS IT LOOKS LIKE THIS:
https://www.awesomescreenshot.com/image/49239890?key=a9a247c5314c3da07ce95db74a8b59ba
As I am not an expert I am really feeling helpless. Why is it happening? Why it is not showing exactly how I designed it from Cloud Templates and TD Composer?
Have you checked for a plugin conflict? Please deactivate ALL plugins except tagDiv ones; also, if you use a child theme or cache plugin, deactivate them, clear all cache, and try again.
Please check this guide, delete the object cache file, and check again https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
@Anamaria
I have observed. My site was Ok for 1 day then its again showing like this:https://www.awesomescreenshot.com/image/49284228?key=a7b171d1a9705f07fde269c7190ed41f
please visit the site now. What I have observed is that THIS IS SIMILAR TO MY MOBILE VERSION. THE MENU ON THE LEFT IS SHOWING PAGES EXACTLY LIKE MY MOBILE VERSION.
After few hours or days it started showing this version. THIS IS SUPER STUPID AND STRANGE BUT THIS IS HAPPENING EVERYDAY.
I disabled cache plugin. I HIGHLY DOUBT THERE IS SOMTHING VERY STRANGE BETWEEN DESKTOP AND MOBILE VERSION. Here are all the plugins I am using:
https://www.awesomescreenshot.com/image/49284511?key=133342e39c61518a31a3d2435c28e30e
*** Another problem I am facing is that i am keep trying to update tagDiv Opt-In Builder plugin. Every time it is showing updated and when I refresh the plugin page, it is showing There is a new version of tagDiv Opt-In Builder available.
Please help me to fix this. I am tired.
Summary: My site https://www.hospitality-school.com/ starts showing mobile version to desktop or laptop users after few hours / days after making any change.
Here are the Tagdiv premium Plugins that I am using: https://www.awesomescreenshot.com/image/49284820?key=688bd2008919f46c2c8e92865687d400
*** SHOULD I DEACTIVATE tagDiv Mobile Theme PLUGIN?
Update:
Reinstall WordPress version 6.5.5 and again now it is showing perfect – NOT MOBILE VERSION TO DESKTOP USERS. I AM PREETY SURE, AS I WILL NOT MAKE ANY MORE CHANGE AFTER FEW HOURS IT WILL AGAIN START SHOWING MOBILE VERSION.
Usually, this happens with cache plugins. If the cache plugin does not have mobile support then the mobile theme version can be delivered instead.
The solution would be to use the recommended WP Super Cache plugin instead and activate these settings (especially the mobile device support): https://forum.tagdiv.com/cache-plugin-install-and-configure/ or you can use WP Rocket.
Also, please let me know what plugin you use for the cache now.
