Category pagination keep looping the same posts?
Hi peeps,
Have been trying to search high and low for a solution but to no avail. I’m encountering an unusual bug on one of the category page where the pagination would just load the same set of posts again and again. Any pointer on where it could have gone wrong? The page in question is here: http://hamiig.com/category/artist-directory/
Cheers,
Sandy
Hello hamiig,
I have checked your website and saw that you are using an old version of Newspaper 6.5.1. Please try to update to the latest version because this kind of issue was resolved in the latest updates. This kind of issue was created by the latest version of WordPress 4.4.1. Please try to update your theme in according to our documentation here -> https://forum.tagdiv.com/how-to-update-the-theme-2/ and also, please update and the Visual Composer like this -> https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
Please do a backup for your additional customization before the update. For more information about backup, please check this -> https://codex.wordpress.org/WordPress_Backups
Hope this helps!
Thank you for the message!
Hi Caitlin,
That works a charm. Will do a site to make sure everything else runs fine, but all seems good for now. Thank you for the prompt assistance!
Cheers,
Sandy
*Sorry, Catalin not Caitlin 😛
