I have noticed that I am unable to insert any additional shortcodes or custom code, hindering my ability to customize the theme according to my specific requirements.
It appears that the current theme lacks compatibility for customization purposes, making it challenging for me to achieve the desired level of customization.
I kindly request your assistance in suggesting alternative solutions or providing recommendations on how to overcome this compatibility issue.
This topic was modified 3 years by
Hindusthanpost.
A shortcode can be inserted by using the element called “Column text” or “Text with title”. For example, in the step3 here: https://forum.tagdiv.com/add-cryptocurrency-price-ticker-widget/
“Column text” and “text with title” elements have a button called “edit content” and if you click on that button, the WP Editor will open, and you can add some text/code/shortcode there. Close the WP Editor from X, save the changes from Composer and view the page to see the changes.
I followed your instructions to edit the content, but the WP editor is not opening. It keeps loading indefinitely. I have attached a video to demonstrate the issue.
https://drive.google.com/file/d/1GVzuxvpWGdeXcvikSxRxFWpMB4GdIFLc/view?usp=share_link
I am seeing this kind of problem with a theme for the first time, where customization is not possible at all.
Please understand that our time is being consumed, and the website is live. We are already late.
Atul C
Please open the console and try to save something.
I think you will have a 403 or 404 error, so please check this topic -> https://forum.tagdiv.com/topic/wp-editor-for-text-with-title-and-column-text-not-updating-content/ and try the suggestions. Also, please check the cache, clear/purge all cache.
Hi Anamaria,
I have tried everything, but still, the WP editor is not opening. It just keeps loading and doesn’t open. Now what is the solution?
Atul C
If you agree we would like to investigate this issue and find out what is the cause, please make a full backup to all files and database and contact us via email at contact@tagdiv.com and provide the following:
– wp-admin URL and credentials
– cPanel/FTP and credentials
Our team will take a look!
Hi Anamaria,
To be honest, I am quite disappointed with the features of your theme, as I had high expectations when I read about it. However, after observing the questions raised by other users in the community, it has become apparent that many users are experiencing issues with this theme, including myself.
It is essential to address such compatibility issues in your theme and mention them on the Themeforest page. Customers purchase themes with the expectation of minimizing problems and reducing the effort required to create a high-quality website. However, in this case, it has become a struggle, and I have even acquired two licenses for the same theme.
Nevertheless, I am willing to provide you with login credentials for the demo server’s WP admin and SFTP access. Please rectify the issue and provide me with a detailed step-by-step description of what actions you have taken to resolve it. This will enable me to implement the fixes on the live server.
I look forward to a quick resolution from your end.
It seems that the problem is because of some conflicts with Cloudways and blocks the WP Editor to load. Please check the settings and also our requirements: https://forum.tagdiv.com/requirements-for-newspaper/
In .htaccess file, this is a problem: https://prnt.sc/Pzq85SpQwT7v
Please check this article too: https://www.cloudways.com/blog/wordpress-500-internal-server-error/
Hi Bettina,
As you mentioned, I have reset all the permissions and even raised a support ticket to cloudways server to reset everything. However, the WP editor for your theme is still not loading.
This is a basic feature, and I have been chasing it, sometimes contacting the theme support and sometimes the server support.
I am wondering if there will be any solution for me. I am unable to open the basic WP editor to insert a shortcode. I am genuinely surprised…
I checked with my team and it if found that the function:
ftp_fget() function is enabled.
It is best here to again check with the theme support and inform them about this error and also that the ftp_fget() function is enabled.
Tue May 30 09:51:13.243121 2023] [proxy_fcgi:error] [pid 22674:tid 139835536434944] [client 49.43.152.254:0] AH01071: Got error ‘PHP message: PHP Warning: ftp_fget() expects parameter 1 to be resource, null given in /home/985718.cloudwaysapps.com/dcszfzvvrt/public_html/wp-admin/includes/class-wp-filesystem-ftpext.php on line 146’, referer: https://wordpress-985718-3463535.cloudwaysapps.com/wp-admin/edit.php
The error is not from the theme. Please let me know what version of the theme and WordPress you have, also, php.
If you don’t have the latest version WP 6.2.2 and theme 12.4, then please update them on a staging website, and try there.
Did you made changes to the theme files?
Hi Anamaria,
This is my live site – https://www.marathi.hindusthanpost.com/
In this website, we have used latest version of theme and latest version of the wordpress.
I have tried various tests with the server, and it has generated these error logs. Could you please check them once?
[07-Jun-2023 13:23:55 UTC] PHP Notice: Function amp_remove_paired_endpoint was called incorrectly. Function called while AMP is disabled via amp_is_enabled filter. The service ID "paired_routing" is not recognized and cannot be retrieved. Please see Debugging in WordPress for more information. (This message was added in version 2.1.1.) in /home/985718.cloudwaysapps.com/gpsyvarnnm/public_html/wp-includes/functions.php on line 5865
The PHP notice you encountered indicates that the amp_remove_paired_endpoint function was called incorrectly while the AMP (Accelerated Mobile Pages) feature is disabled. The notice also mentions that the service ID “paired_routing” is not recognized and cannot be retrieved.
To address this notice, you can take the following steps:
– Verify if the AMP plugin is enabled: Check if the AMP plugin is installed and activated on your WordPress site. If it is not installed or activated, you may need to install and activate the AMP plugin to use the related functions correctly.
– Check the AMP status: Ensure that the AMP feature is enabled. Some plugins or themes provide options to enable or disable AMP support. Make sure that AMP is enabled through the appropriate settings or configurations.
– Review the function call: Double-check the code where the amp_remove_paired_endpoint function is being called. Verify that the function is called correctly with the appropriate parameters and within the appropriate context.
– Debugging in WordPress: If you need more information or assistance in debugging the issue, you can follow the link provided in the notice (https://wordpress.org/documentation/article/debugging-in-wordpress/) for guidance on how to enable debugging in WordPress. Enabling debugging can help identify any underlying issues or conflicts causing the notice.
By ensuring that the AMP plugin is installed, activated, and enabled, and by reviewing the function call and enabling WordPress debugging if needed, you can address the PHP notice related to the amp_remove_paired_endpoint function.
Atul C
Hi Anamaria,
Do you have a plugin for external posts? NO
These are our installed plugins – https://prnt.sc/t-XNVn00osgQ
This is the AMP settings screenshot – https://prnt.sc/NidI5ObaWRap
Please check and let us know
Atul C
Please make a full backup to all files and contact us via email at contact@tagdiv.com and provide the following:
–wp-admin URL and credentials
-FTP/cPanel URL and credentials
-CDN access if you use
Also, during the investigation know that we will disable the other non tagDiv plugins.
Hi Anamaria,
As per your instructions, I have deactivated non tagDiv plugins but still WP Editor is not working.
I have created a new staging website for you – https://wordpress-985718-3609778.cloudwaysapps.com/ and sending all the required login details via mail at contact@tagdiv.com
Please check and let me know if you need anything else.
Atul C.
The problem is caused by the nginx server https://i.imgur.com/uPBij9w.png -> https://linuxhint.com/fix-nginx-403-forbidden/
You need to set the pretty links, you can ask your host to help you -> https://cloudarcade.net/tutorial/pretty-url-on-nginx-server/ -> https://www.cyberciti.biz/faq/how-to-configure-nginx-for-wordpress-permalinks/
