1. I noticed a conflict between td-speed-boosters Rocket wp version 4.5 and version 2.9.3
2. You would use a cahche plugin ??
you can cdn1.site.com for css files, js
and cdn2.site.com for image files (jpg, png, etc.)
using a code in function.php file of your thema?
3 but it is not convenient to use
https://maxcdn.bootstrapcdn.com/font-awesome/4.6.3/css/font-awesome.min.css?ver=4.7.1
It can to your google fonts ??
to speed up the thema …
news about your appearance, good work
Hello orlando,
1)Please keep in mind that the WP Rocket is an untested plugin and over time it has proven to be a problematic plugin and therefore, we do not recommend using this to our theme because you can damage it, sorry! The Speed Booster is an optional plugin, and it works only with the tested plugins.If you use other plugins, it will be automatically disabled, and I suggest to check this first in System Status. However there is a workaround to make it also work with other plugins, you can read more here – https://forum.tagdiv.com/topic/speed-booster-not-compatible-with-vaultpress/
2)Our recommended caching plugin is WP Super Cache. For more information about it, you should consult our documentation here -> https://forum.tagdiv.com/cache-plugin-install-and-configure/
3)Unfortunately, I do not exactly understand what you mean, sorry! Notice that you can use Google Fonts with our theme from Theme panel, like this -> https://www.screencast.com/t/SJSQTTMkOFS9 For more information about theme fonts, please consult here -> https://forum.tagdiv.com/font-customization/
If is not what you mean or if yu need more assistance in this regard, please provide more details about what you want to achieve, provide some useful screenshots for a better understanding and also, so I will be able to provide a more accurate response.
