cpu problem
newspaper theme consumes excessive resources and my sites are opening very slowly. CPU usage is 100% pages are opening very slowly.
Since I have activated another theme, the problem disappears and my site works very fast. but the newspaper theme is extremely slow.
http://i.hizliresim.com/anbAlR.png
Same problem here. CPU and IO usage at 100%.
Hello !
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv Composer, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can check hose topics with a similar situation ->
– https://forum.tagdiv.com/topic/theme-causing-high-cpu-usage-2/
– https://forum.tagdiv.com/topic/sql-querys-high-cpu/
You can try this suggestion to Fix High CPU Load In WordPress -> https://www.ecenica.com/support/answer/fix-high-cpu-load-wordpress/
How to Fix Your High WordPress CPU Usage Problem -> https://www.hostwinds.com/blog/wordpress/fix-high-wordpress-cpu-usage-problem/
Make sure that the php version is 7.1 or 7.2 or 7.3 also make sure that the wp-memory is at list 256MB.
Let me know the results!
hi,
I will try them all. Thank you.
And there’s another problem. can I find out why the share buttons do not exist in the theme panel?
http://i.hizliresim.com/P7Z8b5.png
This issue happens when updating from an older version of the theme so please make this adjustment in the tagdiv composer plugin:
https://www.screencast.com/t/HGX40TlcJgb
Then hit a save in the theme panel and then revert the code back to original .this will make the social icons appear properly again.
Or you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will fix this problem. Include a link to this topic in the email.
I did like the screenshot corrected. but I’m having a speed issue with the theme is incredibly slow Can you help with this?
http://i.hizliresim.com/0054QW.png
The speed of your website depends on how well your site is optimized, if you follow the steps which are presented in this tutorial here -> https://tagdiv.com/how-to-increase-page-loading-speed/ you’ll be able to increase the speed of your website.
Also you can check this similar topic for more solutions: -> https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/
