Cumulative Layout Shift and Mobile Theme
I am using Newspaper theme together with tagdiv Mobile theme on my website.
However when testing pagespeed and layout problems with Google Pagespeed I get several warnings.
Biggest warning (in google search console and pagespeed) comes from Cumulative Layout Shift (CLS) stating: “CLS issue: more than 0.25 (mobile)”.
Is there any way to fix that?
My site is: http://curiousmatrix.com/
First you’ll need to resolve this problem -> https://i.imgur.com/59fPl9j.png so no errors will be displayed in console.
I see that on desktop you have good results, the problem remaining on mobile version.
There are a few things that can be improved, for example the footer ad -> https://i.imgur.com/nNMztjA.png also you can remove the google fonts form mobile theme -> https://i.imgur.com/3V6naPX.png
I hope this will help you!
Thank you Calin very much for your answer.
I did that, but CLS is still not very good mostly because of this:
https://imgur.com/a/e24cwPt
Also, regarding your 1st point, do you have any idea how can I remove this error as I can’t find this file/link/html anywhere?
Thank you,
Domagoj
There are some settings that are not like in our guide because the mobile version is also displayed on desktop, please be sure that the WP Super cache it is set like in our guide -> https://forum.tagdiv.com/cache-plugin-install-and-configure/ also, please try a plugin to optimize the images, if you want you can try those mentioned in our guide -> https://i.imgur.com/k7fW5y1.png -> https://forum.tagdiv.com/how-to-make-the-site-faster/
Great. Thank you Calin.
