Desktop problems
Good morning,
I updated my lottogazzetta.it site with the latest version of the newspaper theme.
On mobile and tablet it goes great, but on desktop I can only view it if only logged in, because otherwise it signals a critical error.
A thorough server side check was done and everything is fine, so I assume it may be theme dependent.
Can you help me please?
Thank you
For that error, please check this article: https://kinsta.com/knowledgebase/there-has-been-a-critical-error-on-your-website/
Hi, I tried, but it doesn’t work. It seems to be the theme, because by testing another one it looks good in browsers. How can I reinstall the theme without losing the work done so far? Thank you
I recommend you to try to use the staging plugin, so you won’t ruin your website, check also this article from here and give it a try: https://themeisle.com/blog/wordpress-staging-site/
Examine some other potential interfering factors: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
Make sure that all the requirements are set as here: https://forum.tagdiv.com/requirements-for-newspaper/
Hi, when I installed the theme I was live-staging, so when I tested it to see how it worked everything seemed fine, and it was because I was logged in that I couldn’t see the error on the browsers if logged out.
Everything else you pointed out to me is fine. I disabled the plugins, but it doesn’t depend on them. I guess it depends on the theme installation because something must have conflicted.
I was wondering if anyone can tell me how to correctly reinstall the theme without running the risk of losing all the work done so far.
Thank you
I recommend you have a fresh WordPress install and move the entire project with the Duplicator plugin.
Hi, I’ve tried them all, but the desktop still doesn’t show up if I’m not logged in. I did several tests with other themes and the problem disappears. It annoys me to go back to the old theme, because it doesn’t guarantee me a valid display of the tables. Do you have any other solutions??? Thank you
This problem appears to be caused by the caching tools you use.
Please recheck!
