When sharing the entries on Facebook the featured image disappears and the web logo appears in the publication, please I need to solve that urgently.
In the social options the whatapp option appears but although you configure it later it does not appear on the web.
I need to configure the cover with only 1 news that occupies everything without having the title above the photo and that option is not in any of the template options, telling me how to do it is important for the web.
I have installed a plugin to register with social networks but it does not appear in the option to comment how I can fix it?
At the bottom of the web I do not find the possibility of eliminating the categories menu, I want it to be one created by me.
WEB CAPTURES HERE = https://wetransfer.com/downloads/f2b095fb52c684f78d8d6458d9b722c020200128192119/58f9db54e3a84ec39ec53fe75f4713df20200128192119/e923e1
Hi danistone,
1. Please make user that the Facebook sharing is set as in our documentation from here -> https://forum.tagdiv.com/facebook-share/ also make sure that this is not a plugin conflict.
2. The block show more posts using the arrows because is a slider -> https://i.imgur.com/R4hSiTz.png you need to use the tagDiv Composer and replace it with a block or flex blocks and set the limit post number -> https://i.imgur.com/80Qt6jy.png also the image need to be regenerate, please check our documentation from here -> https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
3. If this is an untested plugin we can not say if this well work or not with our theme, also we can not provide support for untested plugins.
Tested plugins -> https://i.imgur.com/IDd5qOo.png
Support Policy -> https://forum.tagdiv.com/support-policy-2/
4. The blocks from footer can be change by changing the footer style, please check our documentation for footer -> https://forum.tagdiv.com/newsmag-footer-templates-2/
Hope this will help you!
