Different templates for articles/posts – Possible?
Can I create different templates for my posts/articles?
I have different types of articles that need distinct layouts.
Posts about playgrounds should have a specific design, and there will be 300 articles in this category.
Guides are a different type of article and should have a different layout than playground posts.
News articles should have a third layout.
Is it possible to create a template for each article type, so I can easily select the appropriate one?
Sure. This is possible when using cloud templates. We recommend using cloud/PRO templates to have the possibility to edit them with the TagDiv Composer, which contains a lot of functions and features; please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
More documentation about the cloud templates is here:
– https://forum.tagdiv.com/cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/cloud-library-category-templates/
About pages here: https://forum.tagdiv.com/page-templates-2/ -> https://forum.tagdiv.com/homepage-how-to-build-and-set-it/
Check out this video about how to create a website from scratch: https://www.youtube.com/watch?v=SoGQ0d5kIBg
Hi Bettina,
Thanks for your quick reply – and as always, very helpful! 🙂 I’ll see if I can take a look at it this evening, and I’m excited to get started. There might be more questions along the way, but if so, I’ll reach out.
Wishing you a wonderful day! 🙂
Sure. I’m here to help you!
Have a wonderful day too!
