Extended shortcode – text with title does not load
I built a page using this shortcode – text with title and now I cannot edit it. It keeps loading and does not work. How can I fix this bug? I tried to create a new page and added the code again, but even so it does not work. I am really disappointed.
somosmaes.org.br
Make sure that all theme requirements are set as in our guide -> https://forum.tagdiv.com/requirements-for-newspaper/ in special please make sure this code is set in .htaccess => https://www.screencast.com/t/D3i2ZA7K
Also, if you are using Cloudflare, please make sure that is set as in our guide https://forum.tagdiv.com/cloudflare-cdn/ , you need to disable the Rocket Loader.
Also, if the problem persists please check if you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using a child theme or cache plugin, deactivate them, clear all cache and try again.
Let me know the results!
