Few issues on our website – Speed ,mobile theme and tagdiv
We are working on creating the following website:
http://ideadepot.in/
There are few issues we are facing, can someone help with the solution.
1. The performance is very low, Pages are loaded at least at 60-80 seconds delay and we only have 8-10 static pages. And on wp-admin login it takes more than 180 – 600 seconds for each page load. Over the same internet speed the newspaper demo theme links is working like a flash, so we need to do some setup to improve the speed, kindly guide on this.
2. Our website is not working on mobile phone. It is only displaying a message that no posts are available.
3. Regarding Plugins, if we try to enable “official AMP for WP” a warning message “
Notice: add_filter was called incorrectly. Filter for “amp_is_enabled” added too late. To disable AMP, this filter must be added before the “plugins_loaded” action. Please see Debugging in WordPress for more information. (This message was added in version 2.0.) in /home/ideadepo/public_html/wp-includes/functions.php on line 5225
[edited] on line 6270
[edited] on line 1310
[edited] on line 9”
Also when we access “tagdiv composer page” we get following error – “Delete Notice:add_filter was called incorrectly.
For now we have disabled AMP and our plugins are only the mandatory ones and no the optional plugins.
4. We get a lot of empty column in each page on tagdiv composer edit and they cause visually lot of space on the webpage.
http://ideadepot.in/content-writing/
Thanks for your support.
Hello !
The page speed of your website depends on how well your site is optimized, if you follow the steps which are presented in this tutorial here -> https://tagdiv.com/how-to-increase-page-loading-speed/ you’ll be able to increase the speed of your website.
Also you can check this similar topic for more solutions: -> https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/ -> https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
– https://tagdiv.com/how-to-increase-page-loading-speed/
Please note that page speed is not covered by the support team: https://forum.tagdiv.com/newspaper-theme-support/
For page speed and other services you can contact our custom work team here: https://tagdiv.com/premium-customization-services/
Hope this will help you!
