Getting problem in Latest Posts
All posts in my site (thebankingnews.com) are loading fine except the latest two posts. Means, the posts which are posted after installing this theme showing errors message “There has been a critical error on your website.” at bottom of the post and not showing the sidebar as normal.
Please suggest me how to fix this?
Hello !
Please make sure that all the system requirements are accomplished as you can see it here:https://forum.tagdiv.com/requirements-for-newspaper/
Also make sure that you follow our tutorial in order to learn how to update: https://forum.tagdiv.com/how-to-update-the-theme-2/
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Let me know the results!
