Please see these guides presenting the theme installation
– https://forum.tagdiv.com/install-via-ftp/
– https://forum.tagdiv.com/install-via-wordpress/
The FTP method is usually the most recommended. Follow the steps carefully as described, and everything should work properly.
Also check with your hosting and check these server and WordPress parameters
Insufficient PHP memory can be the cause for this issue.
