Header not changing for posts on mobile.
I am unable to change the header background for posts on mobile devices. It works fine for the homepage.
There is only one global header template from the cloud library.
Site URL: concentratedwisdom.com
You can refer to the video recording below.
https://www.loom.com/share/954cbe41839d49669037a48859310b16?sid=cad37cb5-055f-4c8c-acd9-04a77bd47b11
I can see that you use Elementor. Unfortunately, you can’t use 2 builders in the same time.
We recommend to use cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer which contains a lot of functions and features, please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
More documentation about the cloud templates is here:
– https://forum.tagdiv.com/cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/cloud-library-category-templates/
I have disabled Elementor and all other plugins related to Elementor.
Still facing the same issue.
Please go through the video.
https://drive.google.com/file/d/12FgmNv5SJe1f_2LxKKgdnls1M_0ZZKB0/view?usp=sharing
Deactivate also the Mobile theme plugin and check again.
