Hello, I tried everything but I can’t find a solution to my problem. I`m not using mobile plugin (AMP too) I want show the second section on mobile
This is a desktop version
https://prnt.sc/EIMknxJUS2TM
This is on mobile. The red box and Featured news are missing 🙁
This is my site bnews.bg
Hello @aevtimov !
Edit the mobile page: https://prnt.sc/W1EGDDG9donV and add that element. The mobile header zone is different than the desktop one.
no no, this is a test on my part. I don’t have a mobile page. I just want my header to be responsive. https://prnt.sc/2bGm8YIfzyNt
Hello @aevtimov !
Actually, we have 3 options for mobile versions that you can use:
1. Responsive version: A responsive version of your website looks similar to the desktop version. TagDiv Composer is used to edit the page.Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. There, you can see your mobile version and edit or adjust the elements to look better.
2. Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages
3. Mobile theme plugin: The Mobile Theme is a performance-optimized theme included in the main Newspaper theme that only loads on mobile devices. It comes with its own templates and designs for pages, posts, categories, etc., so your current templates from the desktop theme will get converted to the mobile theme layout. Please see https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/ for more information.
A full explanation is here: https://www.youtube.com/watch?v=SpGkOnJeNZY
If you need to use the mobile version 1 or 2, then you need to disable the Mobile Theme plugin.
You can choose the mobile version and the menu you want to use. By default, we use option 1 for mobile, and you can customize it from the tagdiv Composer.
Yes, i`m using the first.
This is on desktop https://prnt.sc/73-71BQTnyS_
This is on tablet https://prnt.sc/A4xUc3-smob4
but on mobile, those sections just disappear – https://prnt.sc/k5AsLRMUy27-
I just can’t figure out what’s hiding them
Hello @aevtimov !
– admin url and credentials
