This could be a caching issue. Please disable any hosting cache (contact your host) and only use wp super cache and these settings: https://forum.tagdiv.com/cache-plugin-install-and-configure/ If you use a cdn: https://forum.tagdiv.com/cloudflare-cdn/
It could also be a plugin conflict so please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
