@orlando You can also use theme’s speed booster plugin which was developed in this scope, you can find more details on this here: https://forum.tagdiv.com/how-to-make-the-site-faster/
Hope this helps!
You can move theme’s css and google fonts in footer by adding this code in td-speed-booster.php file: http://screencast.com/t/3wlizASZysUv
$this->move_style_to_footer_queue('td-theme');
$this->move_style_to_footer_queue('google_font_open_sans');
$this->move_style_to_footer_queue('google-fonts-style');
We didn’t moved theme’s css at page bottom automatically because in this case there appear a delay with the style on page load. If you move the main css in footer the page’s style will be applied only after the html it’s loaded.
Hi @orlando
First of all check in System Status if Speed Booster plugin is active: http://screencast.com/t/6lILerCjFuAr You can read more about how plugin works in this topic: https://forum.tagdiv.com/topic/mobile-view-problem-3/
Also not that google it’s more restrictive when it comes about page-speed on mobile devices. For example if on desktop you have 90/100 page-speed, on mobile the number will be smaller. This can be checked on our demo. If you look on desktop page-speed you’ll see that there is no render-blocking resource: http://screencast.com/t/pNE7wUbobndD but for the same demo on mobile devices google find a few resources which slow down the page load: http://screencast.com/t/GpmmJ1LHZVPt
To have the same page-sped on mobile as on desktop are required additional customizations and lots of tests. You can follow google’s indications to improve you mobile page-speed but keep in mint that this is a complex task which require some coding skills.
We can’t offer speed customization services at the moment so if you still need guidance on this or you’re not aware of the steps you need to take in this regard please consider hiring a developer or a freelancer to do this for you.
Thanks for your understanding and for your message.
