Help! Posts aren't consistent, nor is homepage.
I’ve got the Say What stack installed, and my website is supposed to look like yours. It does for some people on their computers, but not on others.
Homepage:
http://meanlefthook.com/
Sample 1
Correct post, showing normal sized image and sidebar:
http://meanlefthook.com/2016/11/fox-news-token-black-king-defend-sessions/
Sample 2
Incorrect post, showing huge image and no sidebar:
http://meanlefthook.com/2016/11/taxpayers-spend-millions-protecting-ho-spawn-wont-leavegold-layered-penthouse/
I put my ad code in your customized spots, but ads weren’t showing on the posts that blow up to cover the whole page. I’ve examined closely and see no difference in the way Sample 1 and Sample 2 were written or in the settings.
As you can imagine, significant loss of revenue on what should have been our first huge day.
I have 88K page views today and Adsense only showing 8.4 because of the incorrect posts (Sample 2).
What are we doing wrong?
This looks like a caching issue related to the mobile theme. Please disable the mobile theme plugin and test again. We only recommend wp super cache and these settings: https://forum.tagdiv.com/cache-plugin-install-and-configure/ and for cdn: https://forum.tagdiv.com/cloudflare-cdn/
Also please cotact your host and ask if there is any host related cache as that can influence the theme as well.
Plugins can also cause these issues so please disable all plugins except visual composer, clear cache and rest cdn files if you use it.
If you use a child theme, switch to the main theme to test the posts again.
