Hello Support-Team,
I Have some questions.
First of all: I want disable/delete the Instagram wrap and social counter wrap but how?
and my other question is, how can I change the top post style grid?
I chose the “Grid 12” style but its still “Grid 1” on my page.
Style: http://imgur.com/a/pWwpV
Page: http://imgur.com/a/8ydMW
Thanks! 🙂
Instagram and the Social counter can be added in a page structure as an element, or as a widget in a sidebar. That is how you can remove them as well. Edit your page with the tagDiv composer and remove them from there if they are present, or check the widgets section and remove them from the sidebar
– https://forum.tagdiv.com/instagram-widget/
– https://forum.tagdiv.com/tagdiv-social-counter-tutorial-2/
If you are using the global category setting to change the top post style, please make sure that the other categories settings are set to default
– https://www.screencast.com/t/ktfDDfFRhKn
Categories set on default will inherit the global setting. If a style is selected per category, it will have priority over the global option
– https://forum.tagdiv.com/category-top-post-styles-2/
