I have successfully created a mobile version of my website using the tagDiv Composer without enabling the tagDiv Mobile Theme and Official AMP for WP options. Everything is working fine as expected.
However, I noticed that enabling these two options might further improve speed and optimization. After activating them, I realized that the mobile pages I painstakingly designed seem to not be applied within the tagDiv Mobile Theme and Official AMP for WP frameworks(It is the default theme style).
Is there any way to directly copy my existing styles and setting into the tagDiv Mobile Theme and Official AMP for WP? Or is it recommended to keep these options disabled in my case?
Thank you for your assistance!
We have 3 options available for mobile versions that you can use:
1. Responsive version: A responsive version of your website looks similar to the desktop version. TagDiv Composer is used to edit the page. Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. You can see your mobile version there and edit or adjust the elements to look better.
2. Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages
3. Mobile theme plugin: The Mobile Theme is a performance-optimized theme included in the main Newspaper theme that only loads on mobile devices. It comes with its own templates and designs for pages, posts, categories, etc., so your current templates from the desktop theme will get converted to the mobile theme layout. Please see https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/ for more information.
A full explanation is here: https://www.youtube.com/watch?v=SpGkOnJeNZY
If you need to use mobile version 1 or 2, then you need to uninstall the Mobile Theme plugin and AMP.
