Home page does not match
One other question- why does my homepage not match the Newsmag Homepage. I chose the default homepage and expected it to look like this: https://demo.tagdiv.com/newsmag/#
Instead, it looks like this: https://staging4.divorcemoneykids.com/
I’ve tried changing the Archive templates, but that doesn’t change the homepage. I’m not sure what else to adjust.
You need to actually build your home page layout the way you want.
For example I start with a section full width (a row). Then on second row (side to side); I do [ 2/3 ] [ 1/3]
So, then the left 2/3 is one column to drag and drop different content modules and choose what content categories to load (e.g., news, reviews, etc.), and in right column I drag over widget element, so I can add stuff to right side from appearance > widgets and not in page builder.
I don’t work here but 6+ year user. Good to review the docs and tutorials so you can build out what you want. 🙂
I definitely appreciate your help, simchris! When I try to build out the widget, though, I cannot get it to look like the homepage widget. For example- when I try to add categories in the widget, I do not get to pick/choose the category and it’s just random (which will not work for me because I use “series posts”). It seems like I have to add things to widgets using the basic editor…but I’m also not super versed in using sidebars…I honestly thought I was just going to get what they showed in the demo. That would have been nice.
Hi 2020crystal, the most simple and faster way will be to install a demo – https://forum.tagdiv.com/newsmag-installing-demos/ and after that just edit it. The homepage can be edited suing the theme builder – https://forum.tagdiv.com/tagdiv-composer-tutorial-2/
Oh, awesome! Thank you so much!
