Home Page Showing Same 4 Articles
My Home page of the Parenting template is only showing the same 4 articles in every module (section). When someone visits our Home page they the same 4 articles all over the page. In addition, the Category links don’t adhere to the specific Category that I designate for each article. For instance, if you click on the Java category link, articles from every other category shows up but not a Java post. I hope you can help rectify this problem as soon as possible. I have attached images to show the problems.
Javascript
nullJava
Home page bottom half
Home page top half
You can apply a filter on each block as you want, to not display the same posts, you need to enable the option unique article, which checks if that post is showing in other blocks => https://forum.tagdiv.com/unique-articles/ -> https://www.screencast.com/t/qPztPvlx
This option automatically removes duplicate posts from the page.
Also, you want to have a category template -> https://forum.tagdiv.com/cloud-library-category-templates/ from tagDiv Cloud Library and displayed all the posts from that category, so you can use the posts loop element => https://forum.tagdiv.com/posts-loop/ or you can use Flex Block 1 and set the filter to “Category -Current category” => https://i.imgur.com/7P99qx0.png
