Hello, I been trying to fix this issue for a while. It is esencial that the webpage updates instantly. The problem is that I create a new post and is not visible after a while. The same happens with a change in a page style.
I can see the changes when I am logged in, but when I log out they disappear. I already try to update, fix, delate and re-instal the WP Super Cache Plugin. I followed all the settings mention in the guide: https://forum.tagdiv.com/cache-plugin-install-and-configure/
Webpage: https://www.rotativodemexico.com/
The object cache causes this issue, maybe you have a plugin that creates this one, or you have a plugin cache on the host.
Please check if you have an object cache file stored on your server.
We have a guide on how to check the Object Cache if is applied on the Backend -> https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
Thanks for the response Anamaria. It did solve the problem.
