How do I move the Reviews module to the top of my posts
right now the default setting for reviews are at the bottom of the posts, however, I need to have them right after the featured image. How do I accomplish this?
This can be done by using a template from Cloud templates > Single > Reviews ( https://www.screencast.com/t/K5zsQZ1RfWC5 ) after you get your template will auto open like this ( https://www.screencast.com/t/z82JcRoali ) hover the “Simple post content” and drag it after Review overview, when you see a green row drop it (https://www.screencast.com/t/kblkhN0TNty), save and go back wp dashboard in your post select your post you will like to put your reviews after future image scrool down at Post Settings > General and select at Post template as in our case “Reviews Template 1” and click update ( https://www.screencast.com/t/L17p30mZsA ) ; I hope this will solve your problem.
Hi Calin, I read this post a few months ago and implemented your advice and it worked perfectly. Unfortunately, Cloud Library clashes with wishlist member.
This is the description of the issue.
when my visitors register as a new member they always get the same error message
The username you chose already exists. Please try another one.
However, the user name does not exist. The new user is actually created and they are already logged in. If I register, I get this message but if I click to another page the new user account is created and logged in and everything is fine.
It may be that somehow the submit of the new member is happening twice therefor triggering on the second submit that the user account is already created.
When I disable cloud library, everything works again.
So the question is – can you fix it? Or is there a workaround to getting reviews at the top of posts without cloud library?
Barry
Please be notice that we tested only a few plugins with our theme ( https://www.screencast.com/t/oZYW3ylY0V ).
Please read the Requirements for Newspaper, is possible to need to incise some values like WP Memory Limit.
Also please clear all cache and fore refresh your website.
In order to move the reviews at the top without cloud library you need to edit the post template you have set on posts.
Example for simple template 1
https://www.screencast.com/t/S0Wdzs7QVY
https://www.screencast.com/t/ysSfa5Gt
results:
https://www.screencast.com/t/UkQf6l3ehYk
Hi Calin, my server has 128 MB/request WP memory limit.
Can we please test compatibility with Wishlist Member for the next release of Cloud Library.
In your solution above I tried it and it did not work for me, I copied the code from loop-single-1 into loop single 13 but that broke the loop single 13 template. I do not want to overwrite single-1 as it is my core template for posts.
Here is your Requirements for Newspaper:
-> https://forum.tagdiv.com/requirements-for-newspaper/
If you are using the post template 13 then you need to edit .
https://www.screencast.com/t/t9Ulp6hCohMb
https://www.screencast.com/t/M8u29b5Dr
See results: https://www.screencast.com/t/TCburBxgA1
I tried this but when I select the Reviews cloud template in a post, do I need to use a specific Heading type (H1, H2, H3, H4) to specify a “Product Review Category”?
Say I am reviewing a phone and want to add a review category called “Battery” how do I add it to my post for the Review template to recognize it?
Secondly, how does the Review summary work? What type of formatting do I need to have for the template to recognize it as a “Review Summary”
Hi itechguides,
The review need to be set in post like in our documentation from here -> https://forum.tagdiv.com/reviews-2/
Hope this will help you!
