How to add custom images and slider instead of posts in big grid block
Hello, I want to add images and a slider in the same layout as the big grid flex 2 block. By default it pulls up the posts, but I want to add images with links in the same layout. Please let me know how is it possible.
Unfortunately, for the moment the grids and blocks can be use only for posts and pages. For images you need to use the image elements from tagDiv Composer https://i.imgur.com/tJ4losY.png or you can use with tagDiv Composer a column text or text with title and set in it a gallery -> https://i.imgur.com/KSQqlNu.png
Or you can use some plugin: 16 Best WordPress Photo Gallery Plugins (Compared With Examples)
