How to add slider inside posts
I would like to add a slider inside my posts where i can showcase several images but i couldn’t find any option inside edit post section.I have gone through the forum QA’s and found something like revolution slider ,is it the solution for my question?If it is i tried installing revolution slider zip file included with the newspaper theme but i am getting this message The uploaded file exceeds the upload_max_filesize directive in php.ini. .So how to overcome this issue please let me know
Post pages cannot be edited with the tagDiv composer, so you cannot place the Revolution slider on posts. You can create galleries for example, and slide images
– https://forum.tagdiv.com/gallery-2/
These are all the available post templates
– https://forum.tagdiv.com/post-templates-2/
If you are having problems installing plugins, please check the theme system status and make modifications to the parameters mentioned in this guide if necessary
You could ask your hosting provider to make them for you, as they might have a recommended method in this matter. Insufficient resources are most likely the cause for this to happen.
