How to change the hover color of body text links (SOLVED)
How do I make it so that text in body content has a different hover color when it contains a hyperlink? Example: https://imgur.com/a/K1S8sMS
The circled text should change colors when you hover over it, as it contains a link. I found the Theme Colors section in the theme panel, but it does not have any hover options for links. https://imgur.com/a/K1S8sMS
DISREGARD. I solved it.
  • This topic was modified 2 years by OTAdmin1.
  • This topic was modified 2 years by OTAdmin1. Reason: solved
I’m glad that you managed to solve it.
Have a great day!
Hi! Can you please let me know how to set up a different color of links in Posts and Pages than my main theme color? (where to change the link color for all Posts). I’m happy to add some CSS code if you have any suggestion.
Thank you very much!
  • This reply was modified 2 years by Setrey.
We recommend to use cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer which contains a lot of functions and features, please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
More documentation about the cloud templates is here:
– https://forum.tagdiv.com/cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/cloud-library-category-templates/
Edit the article with the tagdiv composer, click on the article paragraphs, and here you have the settings to change the color of the links, and the second color is the hover color: https://app.screencast.com/sXUXzMpkWiDvm
