Could you explain how to create a layout for 3 text block or images like this?
screen – https://www.screencast.com/t/fTpEx0J4iE
Before your template I used dewfault bootsrap format
example
<div class=”row d-flex flex-wrap” align=”center”>
<div class=”col-lg-4 col-md-4 col-sm-6 col-xs-12″ align=”center”>
text1
</div>
text2
</div>
text3
</div>
</div>
How to it with your CSS?
Hello !
Using tagDiv Composer you can edit the ROW and set it to 3 columns: https://www.screencast.com/t/4lK5gVJK3e
Use one row for the images and create a new ROW with the same layout for the text.
In that way you will have individual control over each element. As you can see here on the upper row you have Single Image element and on the lower one a Column Text: https://www.screencast.com/t/vg8bFAQW
I can’t find such menu in the post
screenshot – https://www.screencast.com/t/ywY0INSnZ
Thanks for the explanation.
Could you advise how to do it in manual mode in the source HTML mode?
Do you have something like this – help manual how to use bootstrap – https://www.tutorialrepublic.com/codelab.php?topic=bootstrap&file=two-column-grid-layouts-for-all-devices
or something like this https://www.tutorialrepublic.com/twitter-bootstrap-examples.php
It seems you have a special bootstrap css format.
I just want to insert some image and text in the formatted “table cells” like this https://www.screencast.com/t/S27Qlt9joH
Cloud Plugin is installed – https://www.screencast.com/t/jCGbYs2qIBs
But I Can’t see it 🙁 screen – https://www.screencast.com/t/p5tKqEtSBhpT
Could you explain – how to add it to the Post page?
Hello !
TagDiv Composer is a page builder not a post builder. You can edit the POST LAYOUT not the Post Content.
Find out how to use the post template here: https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
I hope this was helpful.
Something like this – screenshot – https://www.screencast.com/t/uzKai3xXucw
I just need html code with your formatted bootstrap format.
Hello !
Please note that your request is a custom work request and is not covered by the support team due to our policy: https://forum.tagdiv.com/newspaper-theme-support/
Also for what you want to achieve the easiest way would be to create a table. You can use a generator like this: https://divtable.com/generator/
Copy the table into your post, insert text / images in the tabs you want and that’s it.
I know how to create a 2 cells by table, but this option is not Mobile Friendly.
I don’t ask you to create a such layout, more than 1 week I’m trying to get simple Help article or Manual how to operate your Bootstrap logics for Newspaper X Template.
You didn’t use default Bootstrap 4 for your Template.
In this case, just give me article about this subject.
Is it so hard? :-(((((((((((
Hello !
Sorry for misunderstanding your issue !
Please follow this tutorial: https://www.w3schools.com/bootstrap4/ And make sure that you’re copying the code correctly. Also check to have the proper apostrophe’s ” .
Thanks for answer
But your template doesn’t have such class – div class=”col-sm-4″
Here it is this is simple example with code on post page –
Screen – https://www.screencast.com/t/8lIxsI6A
Bottom part of page – https://prostobzor.com/garmin-swim-2/
so this example with Bootstrap 4 will not work –
Screenshot – https://www.screencast.com/t/hc0K9P2uOm
Give me CSS class name for Newspaper X which operates like a Bootstrap:
class=”container”
class=”row”
class=”col-sm-4″
I didn’t find your response – so this code was commented – https://prostobzor.com/garmin-swim-2/
https://www.screencast.com/t/chbwSThpj
And finally, you gave me Bootstrap 4 help page – but this\ those CSS classes are not supported by Template – there is no such element 🙁
This code doesn’t work for default post – here it is another page = https://prostobzor.com/contacts/
This demo doesn’t work.
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
Thank you
