How to edit pre-built travel website's sidebar and single post layouts
I’ve just installed the pre-built Travel website, I like it as a basis for my blog and would like to customize the layouts, but there are things I do not understand.
1)How do I get to edit the contents in the default sidebar? Or how do i create a new sidebar that retains the same style? In Blog and post template I can create a new sidebar, but there I can just type the name for it, where can I access and actually edit it?
2)How do I edit the single post layout? I cannot find a way to edit it, plus there is no matching layout that I can import from the Cloud library.
I’m not sure which demo you use because we have 3 different travel prebuilt websites.
We recommend to use cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer which contains a lot of functions and features, please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
Documentation here:
– https://forum.tagdiv.com/cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/cloud-library-category-templates/
Check also our video tutorials here: https://www.youtube.com/c/tagdivThemes/videos
Hope that helps you!
